Revision Table Text Alignment
harvey3ELEA
harvey3ELEA
Periodically, I use a "sheet format" template (named FLAT PATTERN & FORMED PART) saved into a drawing file that allows me to simultaneously add a flat pattern & formed part to a drawing, saving the time and trouble of adding those separately (thanks Johnson!).
I've also saw how to delete the original formatted sheet as Inventor tries to automatically create a second sheet (thanks again, Johnson!).
My problem has been that while the first sheet has a center-aligned format in the revision table, the 2nd auto-created sheet loses that formatting.
Is there a way to make sure the center-align carries through while using this sheet format option?
johnsonshiue
Hi! Many thanks for sharing your appreciation! I was not the one implementing the wonderful workflows. The credits go to the Inventor team.
I could be wrong but I don't think such "constraint" is included in the sheet format. I will double-check with the project team and get back to you.
Thanks again!
Software Test Engineer
harvey3ELEA
Thanks.  Looking forward to see what you find out.
I played around with the revision table style to try to maintain the center-alignment of the columns, which applied properly to the first sheet, but the second sheet seemed to ignore it.
Now don't sell yourself short.  While you may not be physically programming the workflows, I suspect they lean heavily on you, your feedback/experience, and what you're encountering with all of our comments out here in the Inventor nether-region.
