revision table need to upgrade
sahmadTMA68
Observer Observer
sahmadTMA68
Observer
Observer
Dear Sir
I am writing this message to request to upgrade the sheets revision window.  I am thankful to Autodesk that we have options to add more revision in one sheets from schematic submission up to detailed design submission but when we wanna submit as  a rev -0 which is related to municipality or client that time we face problem. we have to unchecked previous revision and check latest date only and save as the file because we have to keep record old submission dates also. so i am requesting Autodesk please update revision window as a folder wise lets example i create one revision folder schematic design all the dates and description will be inside the folder same as detailed design and authority submission folder can create and each folder information not relate to each other. just check folder and it will reflect you revision dates and description in your sheets whatever you need just check your folder if you need all check all folder. I hope this request Autodesk will like to upgrade. Thanks
johnsonshiue
Hi! Please submit the idea to Inventor Ideas forum, so other users can vote for it.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/inventor-ideas-en
Many thanks!
Software Test Engineer
robloxapk01
New Member
New Member
It's a very nice idea @sahmadTMA68
dan_inv09
I'm not sure I get it.
Are there pre-release revisions for customer approval, and then post release revisions?
But how does a "folder" work in a drawing that gets printed out?
Is this just the need to have two different revision tables?
(Customer driven revisions and production driven revisions - do they ever overlap? Could this be handled by taking pre-release revisions and copying the revision table to a separate "static" general table, and the "resetting" the revision table for the post release revisions? Are there revision tags that need to be kept and/or kept separate somehow?)
