Revision number not matching rev table.
Every time I use a rev table, I start with revision A which shows up in the table and in my title block. When I want to add a new revision to the table, I insert it under the old one. The problem is that the revision in the title block stays the same as the first revision and does not update. If I change the revision in the first row from A to lets say B, the title block does change and shows B. It just doesn't update when I insert new rows.
Is there some extra step that I'm missing?
Curtis_Waguespack
Hi amarciniakTF6LQ,
Welcome to the fourm.
  1. What method/button are you using to add a Revision Row?
  2. Is the Rev table scope set to Entire Drawing or Active Sheet
  3. Can you attach a drawing here?
  4. What version of Inventor are you using?
I hope this helps.
Curtis
In response to your first question, I've been right clicking and pressing "insert row". Just now I tried pressing the "add revision rows" button and it works. So I guess that was my problem. Thanks!
