Reverse engineering
Reverse engineering
Message 1 of 9
Reverse engineering
I have to reverse engineer part for my department.
I measure everything using my digital vernier caliper.
The results are far from similar.
Infact, there are some errors as I could not get the key pad skeleton to fit in the box.
The keyhole is also having access.
How can I go about reverse engineering?
Accepted solutions (4)
Replies (8)
Message 2 of 9
blair
Better measuring or try Autodesk's Recap. Digital camera with a fixed focal length lens and snap pictures from all angles with 50% overlap.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 9
I have choosen measuring but the whole piece is hard to measure.
I was thinking of measuring the parts inside that is going to be fitted in and design the housing using minimal features
Message 4 of 9
mcgyvr
It looks like an easy piece to model..
Not sure what we can do for you except tell you to practice more.
Seems like you just need more experience..
There are really no "tricks" to reverse engineering..
Its just experience/skill that gets the job done..
If that's a part your company makes don't they have a drawing or model already?
Message 5 of 9
My company buys it from a manufacturer.
They do not have any drawings only the physical part.
Message 6 of 9
MikeKovacik4928
Looks easy enough to model.
Measure it with your vernier,
I used to do this all the time with samples, because
there was either no drawing done, or no drawing available.
If you know the important dimensions and where it fits into,
the measuring from scratch will give you just as accurate a model
as a scanned one, if not better!!
You could get it 3d scanned as well, but that would only
really be useful for more complicated, curvy objects that are
difficult to draw accurately.
3d scanning is very expensive, so an object which is simple
to measure and draw, would be better measured
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
Autocad 2018, Inventor Pro 2018
(and recently Autocad Customisation)
(Impossible only means you haven't
found the solution yet)
Message 7 of 9
JDMather
@Anonymous wrote:
... the whole piece is hard to measure.
Take photos from Top, Front, Side and place and scale in sketches (using a couple of easy to measure features).
Model the part as best you can.
Attach your attempt here.
Message 8 of 9
I have attempted to draw the part but it is nowhere near the actual.
I cannot do the sweep and I have not tried fitting them together.
Message 9 of 9
i'm new in this plattform. If you are still in need just drop me a line and we could check what's possibile.
