I use the same title block for B and D size sheets. I don't see any difference. My title block was defined in the idw template by offseting lines from the edge of the sheet. I then sketched the different cells of the block based on the lower right hand corner, located from the edge of the paper. when I change sizes, the offset stays constant and the whitespace inside the border shrinks.
Steve Walton
Inventor 2024
Vault Professional 2024
