Reseting counting number of browser node name
ivanginato
ivanginato
Ladies and gentleman's, is there a way to reseting parts count number which stays right after the browser node name? If you see the picture below there is just ONE part named "PC-68786" placed on the assembly although the assembly browser shows it's as the second part PC-68786 placed on the assembly which is not true.
johnsonshiue
Hi! The only way I am aware of is to demote those components to a new subassembly. Then the instance numbering will be reset.
Many thanks!
Software Test Engineer
ivanginato
It solved my problem. Thank you!
