Replace Part Command and BOM Relationship
When starting an assembly I'm often mindful of the order I select to bring my parts in so they display the correct BOM number with relation to how I'm going to order them in the drawing's BOM. For example, I will bring in the main part first, knowing I want it to be Part #1 on the BOM (which is hand done and not linked to the actual BOM, due to some parts being able to represent more than one possible part). Often times however, I find I need to replace a part in an assembly, and my BOM number for the replaced part goes to the next available number, and everything else shifts up one. Is there any way to keep the BOM number the same in the part structure when using the "Replace Component" command (ctrl+H)?
(Ignore the fact that the part bubble leaders are blue and the bubbles and text are black, this is an old template I'm using for demonstrative purposes)
