I have some weird patterns on my designed vessel, doesn't matter what material I use, it always looks like this (see attachment).
I tried playing with the display settings, changing the render quality from quality to performance and back, also deactivating raytracing. Nothing seemed to work so far.
Has anyone experience with this problem?
Livi
Solved by Gabriel_Watson. Go to Solution.
Can you atatch the part?
Admaiora
Ok, I have managed to change it by selecting the SRF1 body. Don't select the part, but its body and then change appearance:
OBS: you will need to right-click it and uncheck "Translucent" to see the surface clearly beforehand.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
