Render Image without ray tracing in Inventor Studio
aschalkS7EVV
aschalkS7EVV
Is there a way to just render an image using the shaded visual style in inventor studio that looks like what the user sees in the window? Rendering with ray tracing often gives a worse looking image unless I wait a long time to let it render, and animations are simply impossible to create. I swear I used to be able to do this. I found this image on the forums that suggests that it was at one point possible, did they remove the option in 2024?Pic_1.png
James_Willo
Hi, Studio doesn't actually use Ray Tracing at all. Have you tried going to the file menu and export as an image, does that give you what you want?
Unless you are using specific lighting setups, I actually prefer to render using Ray Tracing outside of the Studio environment.
Here's an example
https://youtu.be/iaPXSj3vWP8?si=J4jHPCAfndr7twwr
James W
Inventor UX Designer
