Message 1 of 15
I am working on a task to add some consistency to existing models. The models are all similar, basically a cube with a door. The door plane being the "front" might be parallel with the XY plane, which is what I want, or it might be parallel with the XZ plane.
Is there any reason I cannot just rename the original XZ plane as XY Plane and redefine "Front" on the view cube?
I plan to use iLogic to create constraints to the origin planes across multiple assemblies. Example of what I plan instead of recreating the actual constraints themselves. Is there any way to rearrange the newly named Origin planes so they appear in the same order as a non-renamed assembly?
Before:
After:
