Renaming file
Renaming file
Renaming file
For some reason, I cannot rename a file in my assembly. The original file is from an IDF import (name: NHA4890322_A65_00.brd.iam) and I want to rename it to "Main PCB Assembly No SIM.iam) but it will not let me. I can save the original file as "Main PCB Assembly No SIM.iam" and it shows up in the folder. I then go to the assembly and select the original PCB assembly in the browser, RMB, select "component replace" and select "Main PCB Assembly No SIM", but it still says "NHA4890322_A65_00.brd.iam" in the browser. If I then open the file from the browser, it goes to "NHA4890322_A65_00.brd.iam".
Confused
Kevin
draftsman3
Make sure to rename the new part iProperties, Part Number - it's under the Project tab in iProperties.
