Renaming File Paths
Renaming File Paths
KaraM12
Renaming File Paths
KaraM12
Hi All,
What is the most efficient way to rename file paths? I put my part dimensions in the file path to keep my files organized. However, these dimensions change quite frequently. When opening an assembly containing the changed part dimensions, I have to reselect the file paths, which sometimes corrupts my constraints.
Is there a better way to do this?
Thanks!
Gabriel_Watson
Your files will be better organized by changing file names instead of paths. Changing folder names is unsustainable and usually a bad practice.
If you use Vault you can rename folders without worrying because the file relationships are automatically updated to keep links resolved. Therefore, if you do have access to Vault Basic through your design package, I would strongly recommend trying to set up a Vault Basic just for yourself.
KaraM12
Thank you very much for the suggestion! I will look into Vault for this.
johnsonshiue
Hi! If you set up your Workspace properly in the project, you can change the path however you like under the Workspace. Inventor will be able to find the files (Library path likewise).
Many thanks!
Software Test Engineer
