Rename filename using Part Number property
eucci
Message 1 of 22
eucci
Hello All,
My usual workflow is to use INV Pro 2023  & Vault Professional 2023 using a sequential serial numbering scheme.
As I work on a project, I develop a sensible numbering scheme (part number) which is different from the sequential filename.
I have encountered an issue where I need to output to a file (preferrably a stp file) for another team member to import into fusion 360 and they need the parts to import with their part numbers (not filename)
Any ideas on workflow would be greatly appreciated
Replies (21)
Message 21 of 22
b.mccarthy
Thank you.
Message 22 of 22
johnsonshiue
Hi! You want to export the Inventor files with the Part Number as their STEP file names?
Many thanks!
Software Test Engineer
