Removing background from circular image added to Inventor
I added an image to my part and when I did I have a black background in the corners. The image I added was circular onto a circular surface so I am looking into removing the black background. Cat Surprised
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Perhaps you should show an image of what you're seeing so we can better understand your issue...
Also indicate the Inventor version and what updates you have applied to Inventor.
Mark Lancaster
Cadmanto
Are your video drivers up to date?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! This may be related to ground shadow or background setting. Go to View -> look at the shadow settings. Or go to Tools -> App Options -> Colors -> change the background.
If nothing helps, please share the file here and the screenshot. Forum experts can help take a look.
Many thanks!
Software Test Engineer
mpatchus
Did you enable the USE MASK option in the properties for the image?
(Right click on the image in your sketch and select PROPERTIES)
Note that if your graphic contains the same color as the background, those elements of your image will become transparent as well.  I always tweak my decal images to make the background a color not used in the actual image (hence the orange in the example below).
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
thank you ❤️
