Remove Cross Section Hatching in DWG
Hello, and Good Day to you, my Friends.
I have a Housing in DWG View.
A Section View with Cross Hatching.
I know it's not practical, but deadline calls.
Is there a way to remove the Cross Hatching in certain areas without modifying the original View?
Maybe an Geometrical overlay?
Thank you in advance,
You are extremely helpful, and I am grateful for your help.
b.mccarthy
Part or assembly? I ask because those areas are fully enclosed, which typically would not occur in a standard part. If this was a multi-body part, a section would show the hatches a different orientations, as happens in an assembly. What is throwing me is that all of your hatches are oriented in the same direction. And I am guessing that you tried an RMB on the hatch and selected "Hide". Did the whole hatch turn off?
Cadmanto
You can RC on any hatch and select "Hide" for any cross sectioned component in a drawing.
What you cannot do is remove just part of the hatch within the same component section.
Now, with that said, depending on what you are looking for, you might be able to adjust your section cut line to instead of being a straight line, be a zig-zag cut line controlling what you want to section and what you don't.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Thanks for the input.
I ended up sketching Geometry over the existing, and applying a solid hatch.
CGBenner
@Anonymous
You can also adjust the scale of a hatched area, as well as the angle.
Chris Benner
