Remove Autodesk 360 Tabs?
This widget could not be displayed.
I'm doing a little housecleaning & rearranging and want to get rid of the 6 "Autodesk 360" tabs (I'm not see ing 6 at once, there are 6 ribbon instances possible).  It used to be easy to remove by removing the panel, but now it's in the tabs (Inventor Pro 2015) and the solution given in the following link no longer serves.
http://forums.autodesk.com/t5/autocad-2013-2014-2015/disable-360-menu/td-p/4298692
Obviously not a huge deal, but would prefer to see it gone. It's uninstalled anyway...I just can't bury the evidence.
Thanks.
blair
Will RMB clicking on the dark strip of the Ribbon Bar and select: Ribbon Appearance>Reset Ribbon work?
Delta Tau Chi ΔΤΧ
Nope. That just nuked my customizations Smiley Sad
blair
Ouch, are you sure the A360 is deleted? It should have been blown away on all applications or have the programers at ADSK added the A360 to all menus in all programs for direct access without the desktop application being installed that shows your sync'd files in the MyComptuer screen.
Delta Tau Chi ΔΤΧ
I always keep a backup of my tweaks for just such an emergency. Yes, I think they've nested that little gem deeper into the system than before; it used to be a 'panel' now it is higer-up.
I'm quite sure it's gone from the computer, I even checked the registry.
<snark> I think it's one of those persistent little 'features' (like the half-baked mini-toolbar **cough**cough**) that you cannot get rid of because managers (@AD) like it. As in "oooh! transparent menus!" or "oooh! we're in the CLOUD!" </snark>
blair
I think it's now part of each software. Probably what you removed was the desk-top aplication that allows access to the sync'd files as well.
Delta Tau Chi ΔΤΧ
No, sir.  It's gone. There is no "Autodesk 360" folder in my favorites, or on my drive (apart from some vestigial images from 2014 I suppose).  The only remnant is in my toolbar.  Oh, well, I'll learn to ignore it.
