Inventor Forum
Refining the mesh used in the Unwrap tool
4 REPLIES 4
werft60
431 Views, 4 Replies
I'm using the unwrap tool to produce a flat pattern for a curved component in a model I've been making (see below). It works great however the mesh is not as fine as I would like it to be. Is there anyway to change the properties of the generated mesh?
Labels (2)
4 REPLIES 4
johnsonshiue
in reply to: werft60
Hi! The short answer is no. There is no user control over the mesh size or density unfortunately..
Many thanks!
Software Test Engineer
werft60
in reply to: johnsonshiue
Thanks for the quick response!
Is there any other way to handle this problem? The unwrap tool is perfect for this situation it is just to imprecise.
Bill_Bogan2
This may not be an answer, but there is a download for meshmixer. I'm not sure if it allows what you're looking to do.
https://www.meshmixer.com/
You might wind up with a lot of roundtripping to get something useful. I've not used it.
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
hfcandrew
in reply to: Bill_Bogan2
