Reference Dimension with Tolerance
ToddPig
Message 1 of 10
ToddPig
I am converting a drawing from Solidworks to Inventor, and (as requested by the vendor) would like to show a tolerance on a reference dimension, as shown.Ref Dim with Tol.PNG
On a side note, I would also like to know if Inventor can show a zero tolerance similar to Solidworks?
For example: "0" vs ".0000"
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Replies (9)
Message 2 of 10
jeffsteiger6735
Yes. Do your dimension and select the tolerance method, but you will need to manually add the reference brackets as selecting reference will remove the tolerance.
And yes as well to your other question. You just set the precision values to whatever you require.
Inventor Professional 2024
Message 3 of 10
ToddPig
Ref Dim with Tol-2.PNG Doesn't look as clean as SW, but doable.  Thanks!!
Any idea on how to change the "zero"?
Inventor 2018
iParts = iHeadache
Message 4 of 10
jeffsteiger6735
You mean the +.0000 to just 0? I don't think you can if the precision is set to 4 decimal places for your - value
Message 5 of 10
aadish.jainQ4JP3
Community Visitor
Community Visitor
May I ask, what is the meaning of giving a Reference Dimension with Tolerance?
I came across this kind of dimension but I can not understand the logic behind this kind of dimension.
Message 6 of 10
cadman777
Neither can I...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 7 of 10
ToddPig
In this case, I was providing a purchased part to a vendor that they were going to modify.  I provided this reference dimension with a tolerance to let them know they could use this feature as a manufacturing datum if needed.
Inventor 2018
iParts = iHeadache
Message 8 of 10
aadish.jainQ4JP3
Community Visitor
Community Visitor
In my case, the tolerance is given on a linear dimension. Can you explain the meaning of this as well ?
Message 9 of 10
ToddPig
I'm not sure, but it could be that somebody in quality asked for these tolerances to be added so they didn't have to look up the tolerance on an H7 fit.  Or maybe they use these dimensions and tolerances as a reference during manufacturing so somebody could make a couple of measurements with calipers or a functional gage.
Inventor 2018
iParts = iHeadache
Message 10 of 10
cadman777
According to standard drafting practice, all reference dimensions should be in parentheses and not be toleranced. They are not to be used to specify feature dimensions and tolerances, so decimal precision and/or tolerances on reference dimensions are meaningless. Also, according to ANSI/ASME Y14.5 GD&T, tolerancing is a complex method for specifying manufacturing precision. I never did work for a company or fab shop that understood them properly. So the way I see it, GD&T only works in mass production scenarios where fits are critical as machine tools wear. They're used for QC purposes on the production line, for example.
This practice must therefore be an 'in house' thing  specific to the cutomer's preferences, just like @ToddPig said. That would be my guess.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
