Reduce precision of length of frame
wowrs1608
wowrs1608
I imported an Autocad single line frame as inventor sketch of a part. Then Using Frame generator to add the 3d frame.
The part list in drawing lists a few parts with very small length differences as different parts. Less the 0.1mm in 1000mm range. They meant to be the same length.
How do I set the precision to let part list thinks they are same length?
Cheers,
Pete
Gabriel_Watson
I think only by grouping those items under the part list (do not select "Display Group Participants"):
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
You can probably get the lengths into a property to be used as criteria for the part list grouping. Try that:
CGBenner
@wowrs1608
I think I would verify the lengths of the sketch lines.  Your frame members should be exactly the same, if all of the sketch lines are exactly the same.
Chris Benner
