RECTANGULER AND CIRCULAR PATTERNS
AnthonyHarris90842
Message 1 of 8
AnthonyHarris90842
Inventor 2024
When I use circular or rectangular patterns in a sketch you do not see a preview of hat the patter will look like.
See image below.
Before 2024 you would see a highlighted pattern
Replies (7)
Message 2 of 8
Mario.VanWiechen
Do not use patterns in a sketch, bad practice
I setup patterns using my sketch to get parameters
Use feature patterns, much easier to edit, can be used for assemblies.
Message 3 of 8
SBix26
While I agree with @Mario.VanWiechen 's advice, I do use sketch pattern on rare occasions.  When I do, I would like to see the geometry previewed as it is in previous versions.  Definitely a regression.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
Message 4 of 8
johnsonshiue
Hi Anthony,
I must not have followed the steps correctly. I cannot seem to reproduce the behavior on 2024. Do you have Section View enabled? What is the Sketch Opacity level (Tools -> App Options -> Sketch -> Sketch Display)?
Many thanks!
Software Test Engineer
Message 5 of 8
JDMather
@AnthonyHarris90842
Can you Attach a file here that exhibits this behavior?
Message 6 of 8
3D4Play
A sketch pattern preview in IV 2024 should look something/exactly like one of these two examples:
Message 7 of 8
SBix26
Very interesting issue-- I tried yesterday before my initial reply, and my experience was the same as @AnthonyHarris90842 -- no visible preview of the sketch pattern.  In order to capture a screen shot to illustrate, I just now tried exactly the same procedure (as far as I can recall) in the same file, and cannot reproduce it.  Previews exactly as expected.
Sam B
Message 8 of 8
AnthonyHarris90842
Hi Gentlemen
I installed an update yesterday and it all seems to be fine again
