Rectangular pattern doesn't follow path
Trying to make a cog belt, but the cogs won't follow the path of the belt.  The loop is closed in sketch mode.
Thomas_Savage
Hello @Anonymous
I have attached your .ipt with the feature following the path.
I will upload a screencast to show you how i done it.
Thomas.
Thomas Savage
Design Engineer
Thomas_Savage
Hello @ross.butterfield
Screencast of how i created the Rectangular Pattern.
Hope this helps.
Thomas.
Thomas Savage
Design Engineer
Xun.Zhang
Like it? file was built by Inventor 2018.
Xun
Thank you for your answer, I will accept it as a solution.
Although screen casts have their uses, the crucial point could be briefly expressed:
To pattern on a path, right-click the path and use Select Other, Curve to select the path.
I would never have guessed this without your help.  Perhaps a note could be added to the Tooltip.
I understand that screencasts allow you to answer more questions, more quickly, which is much appreciated!
Thomas_Savage
Hello @Anonymous
Your welcome.
Yes you need to select other, and select the correct path you want.
Thomas.
Thomas Savage
Design Engineer
MervynThomas6723
Thank You for the video. Clicking the insert button is what made my patterns deviate from the path.
