Rectangular Pattern bug causing part to disappear
RDUNNE2JNG
New Member New Member
RDUNNE2JNG
New Member
New Member
I'm trying to use a rectangular pattern on some solids (Inventor Pro 2025), and when I go to select one of the default XYZ axes in the drop-down menu next to the orange cursor, the part suddenly vanishes off my screen. If I abort the command at this point, I'm able to hit the Home button and the part appears fine. If, though, I continue filling out the spacing info, I'm no longer able to get back to the part; the view cube completely disappears, and the home button does nothing. Undoing did nothing, and trying the "find in window" command also doesn't work. The only solution I found was closing the part completely and re-opening it.
Even after restarting my computer completely, the bug persists. The template our company uses has a lot of features by default that get suppressed, so it might just be an issue when the part gets too large, but I wasn't sure if anyone else had run into this.
johnsonshiue
Hi! I guess either there is bad geometry or the body is extremely far away from the origin. Please share the files that exhibit the behavior here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
