Reading in string values from an excel sheet
I am trying to read in a value with its units in from excel and its giving me an error since I have a string value in the cell.
For example I'd like to read in like "60 in" from a cell.
Does anyone know if this is possible?
Matt
johnsonshiue
Hi! Could you elaborate the workflow a bit. Is it iLogic/VBA? Or, you are linking an Excel spreadsheet to a part?
Many thanks!
Software Test Engineer
S_May
@Anonymous,
here you can practice a bit (inventor & Excel)
This is in iLogic and I'm reading in numerical values by using this syntax:
Variable = GoExcel.CellValue("ExcelFileDirectory", "ExcelSheet", "Cell")
 Although I'd like the option for the user to be able to enter units at the end of the numerical value as well, but when I try entering something like "60 in" into a cell if gives an error.
I was just wondering if there was a way to have iLogic read in a value with a string attached.
Sorry if I didn't give enough info hope this helps.
Thanks in advance!
-Matt
johnsonshiue
Hi! If I understood how iLogic and VBA work correctly, the "variable" will need to be string type as opposed to numerical type.  You can make the variable a string variable or a text parameter. After reading it in, you can use other functions to convert the string value to a numerical value.
Many thanks!
I'm aware that you can bring it in, but I'm having an error doing so. Do you possibly know the syntax or function to convert from a string to double because I can't seem to find anything that works.
johnsonshiue
Hi! In iLogic, you can use Val(String) function to extract the numerical value from the string.
Many thanks!
