If it get the result you're after ... yes.
You might want to think about using a work axis as the axis for rotation. But it comes down to personal preference and
circumstances.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
"Chris Breidenbaugh" wrote in message news:5004170@discussion.autodesk.com...
OK so here's a gif of what I did. I created an additonal solid cylinder.
Inserted an axis. Chose that as my "axis direction" and this is what I
ended up with. I inderstand the i have to turn off visiblity of the
cylinder. Does this sound like the corect procedure to use to generate this
pattern??
Chris
"KJohnson" wrote in message
news:5004138@discussion.autodesk.com...
Is there something to array about, an axis. If not you may have to create
the axis.
KJohnson
