Within the part/assembly, depending what "realistic" view you're after:
With Studio: From within studio render image and save out to a file.
Raytracing/realistic visual style: Get the image on the screen and then save copy as -> change filetype to png/jpg/bmp/etc and save out (the options button will allow you to specify an image resolution).
Within an idw:
Manage tab -> Insert Object -> create from file -> select file and click ok.
By making sure the "link" option is NOT ticked it will embed the image into idw, meaning the image file can be deleted/moved so you don't have to worry about managing the file link (at the expense of a larger idw file).
No idea about dwg I'm afraid, as I use idw, but I'm sure there's a way to import an image into it.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
