Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Raster view to Dwg/dxf file.
Please Help to solve the problem.
I have an Step file & created the detail view, Now I need to convert in dwg. File in raster view
but i am getting the error (Image).
CCarreiras
HI!
The raster state is represented by the green borders in each view. It means Inventor not finished yet calculated all the views.
In raster state there some operations that can't be donne so, Just give Inventor some more time to calculate the views and get off the raster state.
You will notice when the views are off the raster state when the green borders disappear.
This will be dependant on your computer and the model's complexity.
CCarreiras
Without Raster view it doesn't show any complex profile in the object & this i need to use in auto-cadd for my
further process for designing.
johnsonshiue
Hi Marshal,
It sounds like certain edges are not shown in Precise View mode. Is that true? If yes, did you turn on Hidden Lines and Tangent Edges (edit the view -> Display Options -> check Tangent Edges). Does it work better now? If not, please send the files to me directly (johnson.shiue@autodesk.com) or share it with me on a cloud drive of your choice (A360 is free). I would like to take a look at it and see where the problem is.
Many thanks!
Software Test Engineer
Tangent Edges (edit the view -> Display Options -> check Tangent Edges). Yaaaa It worked
Thank you sir.
