Raster View Artifacts stuck in .idw
TBuccieri
Message 1 of 17
TBuccieri
Just got done with >20 drawings. Going to print and I get "One or more drawing views are currently in raster state......". The thing is:
-none of the views are green boxed
-no views have red lines through them
-none have "Raster View" checked in the Drawing View dialog
-"Make Precise" isn't available upon RMB
-"Enable Background updates" has been off since day 1
I copied a drawing and erased everything. This is what you get on screen.
Empty PaperEmpty Paper
And this is what you get upon Print Preview.
Print PreviewPrint Preview
There's nothing in the Browser so where is this image coming from?
Inv2019.3
Replies (16)
Message 2 of 17
johnsonshiue
Hi! Could you share the files here or send them to me directly ([email protected])? I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 3 of 17
TBuccieri
Thanks for the offer, John. I'll send you a file, first thing in the morning.
Message 4 of 17
nate.wilgus
Community Visitor
Community Visitor
I am having the same issue. The only solution I have found has been to erase the page completely and redo it. I can safely copy everything from the page with the artifact, so that leads me to believe it's connected to the page somehow.
Message 5 of 17
todd_cannon
Try this: First go to the respective assembly file and do a "Save All". Next go to the drawing file and update all sheets and then "Save All" again. Check your drawing views. I have had this fix the issue for several of my users.
Cheers,
Todd
Message 6 of 17
johnsonshiue
Hi! Have you tried tuning off "Enable Background Update" (Tools -> App Options -> Drawing)?
Many thanks!
Message 7 of 17
LFMarshall
Just encountered the same/similar issue.  2019.4
All views were up to date, but i received a raster view notice at time of print.
Background updates were turned off.
From a pdf I could see that the geometry in question was coming in on Layer 0.
Turning this layer off and making it a non-printing layer did not remove it from my prints.
Tried copying sheet to a new drawing, did not resolve the issue.
Like was previously mentioned I created a new sheet and replaced my views to get around the issue.
Created a new
Larry Marshall
Inventor 2021.2 , AutoCAD 2021, 3DS Max 2021
Message 8 of 17
johnsonshiue
Hi Larry,
It has been a while since I looked this case. I vaguely remember the cause to the original issue was that the idw file was converted (saved as Inventor dwg at one time and there was some viewports or geometry added to the dwg file). Then it was saved back to idw. That is where it happens.
If you have access to AutoCAD, you can try the following. Open the idw file in Inventor -> save as Inventor dwg. Open the dwg in AutoCAD -> Purge All -> Save. Open it in Inventor. Does the artifact still exist?
Many thanks!
Message 9 of 17
rik_pfau
We've got a drawing with the same issue. I tried your suggestion of purging everything in AutoCAD, then re-opening in Inventor. The artifact still exists. The solution of copying all of the views, etc to a new sheet seems to be the best option.
Message 10 of 17
sundars
Hi All,
This is actually a problem related to a leaked drawing view preview object and not related to a raster view or Enable Background Updates or AutoCAD objects.
We have been chasing this issue for a couple of months now - so far we have had 2 reports come in (INVGEN-24750) but have no way to reproduce the problem. We think that it was a problem introduced in Inventor 2017 or 2018 when a user created a drawing view preview but aborted the view after a series of preview operations (e.g. changing view orientation or any recomputable options in the view dialog). We fixed a similar problem in 2019, but since we have no steps to reproduce this leak, we are not sure whether we covered all the issues.
If you have anyway to reproduce this issue from scratch, please contact me or @johnsonshiue or post steps to this article - it would be of huge help to us in understanding this issue and fixing it.
As a workaround, the best way is to copy the individual views into a different sheet or drawing and delete the original sheet. That should solve the issue. Avoid copying the entire sheet as the leaked object will also be copied.
-Shiva Sundaram
Email: sundarsATautodeskDOTcom
Shiva Sundaram
Inventor Development
Message 11 of 17
sundars
Hi All.
This issue was also reported in https://forums.autodesk.com/t5/inventor-forum/realign-auxiliary-views-command-creates-hidden-raster-...
We have fixed the issue and the fix should be available in the latest updates for 2020 and 2021.
-shiva
Shiva Sundaram
Message 12 of 17
4thAxis
I'm using 2022. my views are stuck in raster view, I never enabled it anywhere, check box in "edit view" is unchecked, I went into the application options and disabled background updates, still in raster view.
Just tried copying to a new sheet and that still fixes the problem.
Details:
I created a mold of this part first, then exported the face that will be the part, into a DXF. I then made a sketch and inserted the DXF. I extruded the part from the sketch that is using the DXF.
I used the part in an assembly and the assembly in an IPN, as well as Inventor Studio.
Message 13 of 17
sundars
Hi @4thAxis
This issue looks dataset specific where the view itself has not been converted into a precise view. It's possible that the something went wrong with the background compute. It doesnt look like the original issue described on this thread which is about orphaned previews. I assume that you can edit the view and can also highlight it from the browser.
In anycase, if you can share your model with us we will gladly take a look - please email part/drawing to "sundarsATautodeskDOTcom.
-shiva
Shiva Sundaram
Message 14 of 17
jversteegUGNLW
This issue is not fixed. Still can happen in 2022
sundars workaround: copy the individual views into a different sheet or drawing and delete the original sheet still works
Message 15 of 17
sundars
Hi @jversteegUGNLW
Can you reproduce this issue from scratch on Inventor 2022? If so, we would greatly appreciate steps to reproduce and a dataset. If it's an old drawing, yeah, then that would explain the issue.
Thank you
-shiva
Shiva Sundaram
Message 16 of 17
jversteegUGNLW
I was unable to reproduce this. The drawing was of a new part just drawn yesterday. It had issues as soon as it was placed in sheet space. (Didn't have any line entities in view one to auto dimension off of.) I tried to re-create today and just can't get it to happen. It occurred on two out of three drawing files in the batch yesterday both of which are now corrected.
Message 17 of 17
sundars
If you are able to share your model with me I am happy to play with it to see if I can reproduce it using previously known workflows. You can email it to me at: sundarsATautodeskDOTcom
Otherwise, lets continue to keep a watch on it.
-shiva
cc: @t_pcoll
Shiva Sundaram
