RAL-color library
RAL-color library
TobiasZetterberg2067
Message 1 of 40
RAL-color library
Hello!
I work a lot with industrial equipment and components which are often delivered painted in RAL-colors (4 digits).
Therefore I created a complete RAL-color library with a painted look (gloss and reflectivity).
I believe in sharing useful things to others so here is the RAL-color library.
I had to split the file into a mutlivolume zip due to the file size-limitations for this forum (<5 Mb).
The first part is in this post and the second is in the post below.
You can see how to attach it in:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-98E276B9-ACFC-40CF-8FFB-D9D081D4C207
Below is a overview of the library.
I hope someone find this useful!
/Tobias, Toze AB
Accepted solutions (4)
Replies (39)
Message 21 of 40
I used the file but Revit LT says the library is empty.. any solutions?
Message 22 of 40
AlexFielder
This Library is formatted for Autodesk Inventor. Not Revit. (hope that helps)
Message 23 of 40
chris
what is the correct method and location for adding these colors?
edit: sorry missed that initial link
edit: Okay followed the method in the link as well as stated in the other replies. computer won't unzip the first folder nor will it allow me to copy out the .absklib from that zipped folder.... so I am unable to make this work. Could someone do a screen capture for myself or anyone else who might be having trouble getting this to work?
Message 24 of 40
Hi!
Try using the unnzipped file from my googledrive instead:
https://drive.google.com/open?id=0B9_OlPHjbi6wUkIzaml2dUp6THc
Once you download it you should be able to move it to your desired location and attach the library by managing your project folder (or from appearance browser if you just need the colors for a specifik part).
/Best regards Tobias
Message 25 of 40
tvb
Observer
Observer
Thank you so much Tobias Smiley Happy
Just imported your RAL colours - it works nice and is a great help for me - again thanks a lot.
Kind regard
Tove Virkelyst
Message 26 of 40
I have downloaded both of the links in the solved post and nothing works?
I might add I am trying to do this in Revit.
Message 27 of 40
Try the link to googledrive in a post above, it should work just fine.
I dont know if it works in revit since it is an Inventor-library.
/Best Regards T
Message 28 of 40
Thanks, I managed to download the file fine, it is just empty when I tried to use it in Revit Material Library.
Not to worry!
Message 29 of 40
AlexFielder
That's because as previously stated in this thread, the library is for Inventor, not Revit.
Message 30 of 40
Thanks, to be honest, I didnt read the whole thread as I was in the middle of design work!
Hopefully someone will make the same for Revit Smiley Happy
Message 31 of 40
AlexFielder
Actually, this Library does work in Revit but you have to do two things:
  1. Remember that this is an appearance library, NOT material library.
  2. Use the Revit Asset Browser to open the Library, in the same way that you use the Inventor Appearance Browser to open the file.
2018-01-10 11_08_26-Autodesk Revit 2017 - Not For Resale Version - [Floor Plan_ Level 0 - Project1].png
Once you have them open in Revit, you can apply the appearance to any material you choose as per Inventor.
Message 32 of 40
Thanks thats great news as we work with RAL colours every day!!
Message 33 of 40
AlexFielder
You're welcome!
Message 34 of 40
thom-g
@TobiasZetterberg2067: Great work!
By the way: I was able to unzip your zip files with 7Zip and winzip. All I had to do was to rename the second zip fie from "RAL_colors_001.zip" to "RAL_colors.z01" (7Zip told me that). Maybe you could rename the file and/or upload it again...
Message 35 of 40
Thank you for taking the time to do this.
It'll be really useful for me and nodoubt hundreds of other users.
Many thanks
Stuart
Message 36 of 40
J.J.Kucharczyk
Great job Tobias! Thank you !
Message 37 of 40
Manuelcamposcosta
THANK YOU SO MUCH! I WOULD KISS YOU! HAHAHA
If someone is finding problems with the original files I attached them again in a simple way.
Manuel Campos Costa
Message 38 of 40
Tobias
YOU'RE AMAZING!!
Message 39 of 40
kbuM6G4J
Community Visitor
Community Visitor
Im using the 2022 pro version of inventor.
Im new to materials and appearances.
It says it fails to load the libary at the current location. Does anyone have a little "how to" guide to put this in use?
Im properbly doing it the wrong way.
Does the adsklib files have to be in a specific folder? I just put them somewhere and added them to the libary insde appearence browser.
I hope im not alone with this, lol.
Best regards.
Message 40 of 40
AlexFielder
You need to add the .adsk library to whichever Inventor Project you are currently using:
