"Select as edges" error
mohandis2
mohandis2
In Inventor 2018 dwg document, when right clicking on an item in the browser and select "Select as edges"
Error fatal accurses and inventor shuts down, any solution to this please?
Thanks.
kelly.young has embedded your image for clarity.
mcgyvr
Thanks.
first.. Have you installed all updates for Inventor? IF you haven't do that and see if that potentially fixes the issue..
Its likely a problem associated with your particular files so Autodesk would need to see those to identify the specific part or geometry causing the error.
Can you share the model files so that someone can see whats causing the specific problem? (pack and go)
johnsonshiue
Hi! When Inventor crashed, did you submit the crash report? If yes, please send an email to [email protected] so I can take a look at the report and understand the behavior better.
Many thanks!
Software Test Engineer
mohandis2
I did sent the report with descriptions
johnsonshiue
Hi! Please send me an email ([email protected]) so I can find your report.
Many thanks!
