"Justify Text to Leader" not overriding text styles
DayGriffin5218
Message 1 of 1
DayGriffin5218
I see that a lot of people are trying to override the "Justify Text to Leader" feature, and the solution is as simple as unchecking the "Justify Leader to Text" box, however, I am having the opposite problem. All of my Dimension Objects are set to a certain Object Style for which I have the "Justify Text to Leader" box CHECKED. When I drag, for example, a radial dimension, and enter additional text below it, it will not justify to the leader. Yes, I can change the justification manually in the "Edit Dimension" window, however, the point of the "Justify Text to Leader" feature is so that one does not have to.  Please help.
Replies (0)
