@johnbDWWDB wrote:
If Inventor can do it automatically, then that would work.
Inventor can do it automatically, and that's why you can't edit the sheet number. It's an automatic thing determined by the order and number of the sheets in the drawing. So generally, if you want the sheets in a different order, then you put the sheets in that order. The system takes care of the numbering. I've used Inventor since about 2006, and have never seen a situation where manually changing the sheet number was needed.
As for your issue with "Exclude from Count":
- If you have two sheets, and then exclude one of them, it should say "sheet 1 of 1", just like it would if you only had a single sheet.
- It would say "blank of 0" if you exclude all of the sheets - in which case the sheet count of 0 is technically correct. That would be the case if you only had one sheet in the drawing when you tested the exclude setting.
You said that you "added a second IDW", but I'm not sure what you meant by that since you can't add an IDW to another IDW. This may sound like I'm being nitpicky about terminology. But the phrasing makes it unclear what you actually tested, so it's hard to know what really happened without clarifying this point.
