"Error loading segment designview segment in database inventor autodesk"
projetos
Message 1 of 9
projetos
Today I copied a part inside Vault, and after modificating and saving it I tried to open it again. The messages "The current operation requires data from document X:\Workspace\Projects\Designs\Inventor\Parts\C0007638.ipt, but it cannot be found. The document may have been moved, renamed, or deleted. The operation must either be aborted or the file located." and "Error loading segment designview segment in database inventor autodesk..." appeared.
The file was in the right place with the right name. Before going looking for an answer, I thought that since Inventor was looking for the C0007638.ipt file and in the folder there was no extencion appearing, that was the problem (ignoring that windows ocults it). So I put a .ipt as part of the file name (C0007638.ipt.ipt) and the Inventor recognized it and opened it perfectly. But it only works with the second .ipt at the end.
After it I came here to look for an answer and found a post (https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Users....) saying that the better option is to just restore the latest version.
I'm going to do it, I just wanted to know if you guys have any comments about this situation. Apparently the file isn't corrupted, it's just a matter of file name.
Update: I just restarted the whole process from Vault and ended up happening the same thing.
Replies (8)
Message 2 of 9
johnsonshiue
Hi! Likely the file is corrupted. Somehow the Design View segment cannot be loaded. Do you have the backup files? If you find out how to reproduce the corruption, please let us know asap. It will be very helpful to finding a fix.
Many thanks!
Software Test Engineer
Message 3 of 9
t.kochGSBTV
Observer
Observer
Hello guys,
was the problem able to get retraced?
Thank You in advance
Thomas
Message 4 of 9
johnsonshiue
Hi! The error message only indicates the symptom but it does not identify the source of the problem. Basically, the file is corrupted for some reason. If you can find the steps to reproduce the corruption, please let us know asap.
Many thanks!
Message 5 of 9
valekperov
Community Visitor
Community Visitor
Hello, we have experienced the same problem, it seems to be happening when same file is open on different inventor windows, after closing second one issue was resolved, hope this helps
Message 6 of 9
SER4
I had to close the entire Inventor application and then it worked...probably kept the 'old version' stuck in memory or something eh.
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
Message 7 of 9
peter.kapitola
That worked, thanks!
Message 8 of 9
cosmin_andronic952G9
I encounterd this problem and I deleted the design view related to the model state and afterwards i copy it again from the model state. And the error disappeared
Cosmin
Message 9 of 9
Mehmet_Fatih_Turker
Hi all,
I was getting designviewsegment error, In my case, I deleted an attribute that is created by somehow. Then stopped getting error.
