question
question
question
QUESTION: How can l simulate the rotary draw bending process. l am using Autodesk Inventer 2015. l want to prove through simulation that l can bend a pipe at a certian centre line radius to produce a bend that has cosmetic perfection.
The properties of the pipe: Material -Mild Steel
                                          Normianal Pipe Size - 1
                                          Out side diameter -33.4mm
                                          Schedule -80
                                          Bend angle - 180
                                          Centre line radius - 100mm
l also want to aminate the process after simulation. The process is on the video with the link provided below.q
Xun.Zhang
if I understand correctly, Fatigue simulation is something you want. if so, please get the product Autodesk mechanical simulation and check with the Fatigue function.
Hope it helps a little bit.
Xun
JDMather
@Anonymous wrote:
...l also want to aminate the process after simulation. ...
