@Anonymous wrote:
Well they is as in the owners and and the tool and die maker but the people i need to send drawings to were for UL engineers.
Ok.. getting better.
I understand a bit better now..
Yes you need to include more dimensions and a cross section view showing the louvres..
I'm not sure which UL standard your product will apply to but I absolutely suggest you read it if you haven't already..
There are usually dimensions in there that "openings" must apply to..
But you don't state anything about the spacing or angles of the louvres in the drawing..
A cross section and a few more dimensions should be all thats needed..
The UL standard my products are applicable to is more concerned with the entrance foreign conductive objects into my products so they have specific requirements about the size, spacing and angles to attempt to mitigate the possibility of anything falling in and shorting out/causing fires,etc... All that is spelled out in the UL standard.
I'd expect yours is more focused on water egress,etc...
