pull assembly file parameters to idw
how do I pull user parameters from iam file to idw, I want to use these parameter to build a form in idw.
So I can change these parameter values from my idw file.
any help is appreciated.
asiteur
If you want to do these kind of things you'll need to pull the variables from the component (part or assembly) using iLogic.
See this sample statement
local_parameter = Parameter("MyPartORMyAssembly", "MyParam")
Make sure that the parameter is already defined as a user defined parameter.
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
