Publishing Multiple IDW's to single PDF (file name)
lscadden
lscadden
Maybe this has been resolved but we are looking for a viable solution to publish a single PDF from several individual single and multi-sheet IDW's i.e. different individual file names to one PDF.  I have looked at Batch Plotting from Inventor and Vault 2023 and looked at using the Task Scheduler, even tried the Drawing Porter utility (app) from the Autodesk Appstore to attempt this however I keep running into the same issue where it tries creating a bunch in single PDF requiring me to type in the name after creating each file.    What I want is to direct print / publish a bunch of .idw files to a single PDF as though it were a scanned in file rather than 80 (or more) single files.  Note; this is what we do now is print everything out hard copy and scan...  OR we print everything out individually as a PDF and combine using adobe ...  this is all way too time consuming.   I understand this would be a prodigious sized file but this is how we store project files electronically now.
Using Inventor Vault 2023  or is it possible this has been considered or better yet made an option in later releases as a tool?  Might be over shooting my expectations but to select a top level assembly and enter a single PDF name up front and have it find all the associated idw's (all sheets) and publish 1 PDF of all would be ideal. (or impossible).
thanks,
Lukes
Ray_Feiler
Try one of these. pdfmerge - Search
https://www.bing.com/search?q=pdfmerge&form=ANNH01&refig=79e96a0b719347d8a80094805ea80602&pc=U531
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
lscadden
Thanks, these all work in combining PDF's as does the Adobe product I have, albeit these are free.   However, what I want to accomplish is, and it may not be possible, to select multiple Inventor .idw's and set them up in a list somewhat like I would do in Task Scheduler or Batch Plot and print to all of the .idw's to a single PDF.   Merging several PDF I can do, I'm trying to not open every drawing and first print each file to its own PFD then combine all those to one PDF.  I'm trying to skip that part.  Shown in the attached image is what I'd like to accomplish.  However, trying to use Task Scheduler with these, it stops and forces me to enter a PDF name for each file in the list.
This might be a wish list item but what I would like to see is the ability to set up a task or list of .idw's and enter the 1 single PDF / file name, which in our case would be a project number, right up front and hit go the output would or could be a 60, 80 or maybe many more page PDF.    Which in our case we zip and archive with all the other project BOM's Purchase Req's and information.
