Promoting/floating certain consumables and loose items to top level of BOM
Sometimes there are loose parts or consumables that get used at various levels of an assembly, but always need to be tallied up and listed at the top level BOM. Consumables are one example (glue, paint, etc.). Another example might be an "ID tag" that gets attached to each instance of "Part X" in the field. The total required number of these tags needs to be tallied up and listed at the top-level for a project, but a tag needs to be included for every instance of Part X, at every level. Another example would be bolts and washers that go with every instance of "Part X".
Currently, the closest way to do this that I know of is to make a "package" assembly that contains Part X plus its loose components (ID tag, bolts, or whatever), and set the package assembly as Phantom. Then, place the package assembly wherever Part X goes, rather than Part X by itself. This ensures that the required loose parts are always included (both in the model and the BOM) with every Part X. The same thing could be done for consumables that go with a part or assembly.
However, the result of this approach is that the loose parts/consumables are scattered about various levels of the assembly structure, wherever Part X happens to be. And there's no way to get all the loose parts to float to the top level without making a bunch of assemblies "Phantom" that shouldn't be Phantom.
I haven't been able to find a good solution to this. So, I'm creating this post to hopefully get some answers to the following questions:
- Do you know of a good way to do what I described above?
- If not, have you experienced a similar need, and would you benefit from a good solution?
- If #2 is "yes", do you have any thoughts on how this ideally could work? For example, how would we tell Inventor which parts need to float to the top, and how would we tell Inventor which assembly is the "top" one? Should floated parts be listed in intermediate assembly BOMs as well, or just the top one, or should this be an option?
If you have any answers to the questions above, or other thoughts on this topic, please do share! Thanks in advance for any contributions.
