projecting points
projecting points
projecting points
I am doing an import of a large number of points from excel. I also needs those points on two other planes to create additional geomtry and I am trying to figure out if I can somehow project those points so any changes to the original set would follow. I can individually select them point by point but I cannot seem to drag and select all which becomes difficult as some of our layouts have 5000+ holes.
Any suggesions or workaround would be appriciated.
JDMather
Convert to a Sketch Block and then copy the block.
Changing the block should change all instances.
