Project file configuration (How to remove the "Included file" path)
GabiWearing
GabiWearing
Hi all you Inventor specialists,
I messed up my project file by adding  another project file in the "Include file" box but it is wrong and I don't know how I can delete it.
I did this outside of inventor in the project editor.
Can anyone tell me how to remove the included file please?
The reason I have done this is that I created a new project with a different content library (DOBBIE-PROJECT because I wanted to add some material to bolts and change some sizes.
The problem is now that all my assembly files where I have previously used bolts have a lost their connection to their original system content center files.
I was hoping to be able to swap all of the old bolts with the ones in the new content center which is now read/write but it takes forever to open the assembly files because it searches our whole network drive for the bolts I had used before all these changes.
I wonder if there is a better way to get the search time down.
Any help is much appreciated, thank you
Frederick_Law
Switch to Default project then you can edit the other Project
SBix26
Right click on it and pick Delete:
Note that you cannot edit a project if there are any files open.
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
GabiWearing
Thank you, I knew it would be easy... just didn't know.
