Problems with section view
molnarnoemiandrea
Message 1 of 9
molnarnoemiandrea
I did a draw (.idw) from an exported step file, that I saved back to .iam. And when I try to do a secton view on the drawing it says that problems encountered while executing this. How do I fix that?
Replies (8)
Message 2 of 9
JDMather
@molnarnoemiandrea wrote:
How do I fix that?
Can you Attach the files here?
Do the imported bodies pass quality check (green checkmark)?
Message 3 of 9
molnarnoemiandrea
Here are the files
Message 4 of 9
Alexander_Chernikov
Hi, if you work in Inventor 2021, have you install the latest update (2021.5)?
Next, the problem may be with multibody part also-rész.ipt - try to Combine "Solid2" and "Solid2:1"
After Combine its work (I cannot add file, because I use AIV 2023)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 5 of 9
molnarnoemiandrea
When I want to combine (in the ipt file) it says the part must have 2 bodies (so my also-rész.ipt is one body).I use Inventor 2021, and I've never had a problem creating section view before.
Message 6 of 9
johnsonshiue
Hi! The files are incomplete. I tried importing the STEP file and did the sanity check (Ctrl+F7). "nyitokar.ipt" seems to check bad. Open the part and right-click on the base feature -> Repair Bodies -> Find Errors and then Heal Errors.
After that, does the drawing section view work better then?
Many thanks!
Software Test Engineer
Message 7 of 9
molnarnoemiandrea
I healed the errors in nyitokar.ipt, but it is still not working. It says that there is something wrong, with also-rész.ipt. But I do not know what's wrong.
Message 8 of 9
Alexander_Chernikov
I  see 2 bodies, in video is example of Combine
(view in My Videos)
Facebook | LinkedIn
Message 9 of 9
molnarnoemiandrea
I don't know why, but my modell tree is a little bit different than yours.
(for me it is solid bodies(1) ) And I can't combine these.
