Problems with representing parts while sectioning for render on autodesk inventor
ricsoarfilho
ricsoarfilho
Hello everyone i've been having some problens to represent sectioned assemblies on inventor, while sectioning the assembly trhough inventor view panel as show below the part the assemby would just section all components, but what i need is the shafts and gears to remain whole. I will be sending a image of how my looks and what it should look like (please do not take in account the image quality).
the option view representation i choose:
what it looks like the way i do
the way the parts should be represented
James_Willo
I don't think you can do this with section view. You can try doing this with the extrude command.
Create an assembly level extrusion and then remove the participant.
(view in My Videos)
James W
Inventor UX Designer
James_Willo
You can also use this option at part level. Forgot about this. Open document settings in the part you want to ignore sections. Will make it ignore sections for drawings and modelling every time the part is used though.
James W
