Problems with converting units.
Message 1 of 8
hello,
I am new to inventor and am having trouble when I import my AutoCAD .dwg files.  They are drawn in AutoCAD in mm, but when I open them in inventor, they display as inches.  there has been no actual conversion, but the output is saying the wrong unit.  For example 12in rather than 12mm.  I have tried to change my default template to mm, but the problem persists.  Is there no way to simply change the units like there is in AutoCAD Format -> Units...
Replies (7)
Message 2 of 8
Ray_Feiler
In AutoCAD make sure Measurement is set to 1.
Command: MEASUREMENT
Enter new value for MEASUREMENT <1>
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 3 of 8
CCarreiras
HI!
Make sure you are open the (mm) template.
How are you importing the Autocad doc? From the sketch?
CCarreiras
Message 4 of 8
I am simply pressing the file open button on the top left of the screen.
Message 5 of 8
JDMather
@Anonymous wrote:
...  They are drawn in AutoCAD in mm, but when I open them in inventor, they display as inches.  ...
Can you attach an example AutoCAD file here?
The first test I am going to run is -dwgunits.
Message 6 of 8
Thanks for the help.  I have attached the file I am having trouble with.
Message 7 of 8
rhasell
Hi
CarlosC got it, theMeasurement option worked.
What you have to do in inventor is change the detected units from "Inches" to "mm"
Works a treat.
Reg
2026.1
Message 8 of 8
JDMather
I recommend that you create a new template for your AutoCAD work as -dwgunits indicates your current units were inches.
