Problems with chain drive generator
planner_mobbs_engineering
Hey Guys, I have been stuck with this since yesterday. I am trying to insert a chain drive in the assembly since yesterday. Everything works fine but i cannot see the links in the chain drive. Please see attached screenshot.
Gabriel_Watson
Inventor is not capable of adding the individual links, so that's pretty much what you get with the design accelerator... however, if you want to change the chain to at least not be transparent, you can go ahead and edit the chain part and change its appearance from "Clear - Blue" into something more solid.
To model chains fully you'll need to work a bit more:
A more complete tutorial also here:
Okay, Thanks a lot.
