Problems opening Solidworks files.
timsautodesk2015
Message 1 of 11
timsautodesk2015
The engineering department here has updated Solidworks to its latest version, and now the latest version of Inventor wont open the files. Inventor gives me a prompt to download the latest Inventor, and I have the latest version...What can be done about this?
Replies (10)
Message 2 of 11
CGBenner
@timsautodesk2015
It may be that someone with access to the Solidworks files natively will need to export them as an earlier version so that Inventor will open them.  The newest version of SW is probably being seen as newer than the latest IV version... hard sometimes to keep them in sync.
Chris Benner
Message 3 of 11
CCarreiras
Hi!
these are the most updated translators available in Inventor 2023.2.1:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-AF41FA87-7588-4698-9C41-756A01EBE7F4
CCarreiras
Message 4 of 11
ampster40
The rule of thumb here used to be that what ever version of Inventor you are using, you can usually open up one SW version behind Inventor, up until the last Inventor service pack applied to any version.  That last SP update usually takes care of allowing Inventor to open "the same version" of SW - as long as the companies keep using the year as a version number indicator.
Message 5 of 11
johnsonshiue
Hi! The latest SWX file import support is usually on the coming Inventor release and the .3 update for the current release. It should be available soon.
Many thanks!
Software Test Engineer
Message 6 of 11
timsautodesk2015
Do we have any idea as to when the .3 version is suppose to release? As of right now, I can't open any files from my engineering dept., and it is hindering work BADLY.
Message 7 of 11
Frederick_Law
Request Parasolid files from SW.
Message 8 of 11
johnsonshiue
Hi Folks,
2023.3 is being finalized. It will be released some time in April.
Many thanks!
Message 9 of 11
timsautodesk2015
Will ANYCAD open newer versions of Solidworks?
Message 10 of 11
JDMather
@timsautodesk2015
Have you installed Inventor 2024?
Message 11 of 11
timsautodesk2015
No I havent, I was waiting until CAM Ultimate 2024 comes out.
