problems installing inventor pro 2016
I'm having some trouble during the installation of "Inventor 2016 pro"
after I choose to install the program selecting "install now" it starts to download but it alwais gets stuck when it's downloading "low image library"
I have tried several times to repeat the process (checking all your suggestions on the community) but i still can't get through that point
I attach the installation log file that appears after every download
I hope that you can help me as soon as possible with this problem
Thank you
Mark.Lancaster
Don't use the install now option.  Go to the Autodesk Virtual Agent and follow the download links.  Once all the parts are download, go to your download folder and extract (double click) on part 1 and after a couple of secs the exctraction will take place.  It will extract to C:\Autodesk and once done the installation will take place.
Autodesk Virtual Agent: http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Mark Lancaster
If nothing works maybe try restarting your computer, maybe it will help.
