Announcements
problem with select side for threading in 2020
MIRKO_G
MIRKO_G
The side for partial threading is not recognized when using the function with complete default and then changing to partial.
I attach a small video.
in previous versions this event was recognized.
Autodesk Inventor 2015 Certified Professional
Autodesk Inventor 2018 Certified Professional
Autodesk Certified Instructor - Platinum
Fouad-l
Hi @m.girlanda you can select which side by clicking on it.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
MIRKO_G
of course. but before choosing the surface I have to remember "full depth OFF".
1-full depth OFF
2-select side surface
in previous versions I didn't have to remember this sequence.
johnsonshiue
Hi! Yes, there was a behavioral change starting from 2016 or 2017 in this workflow. The change was meant to avoid directional confusion in thread feature.
Many thanks!
Software Test Engineer
MIRKO_G
eventually it would be useful to set the use of the "complete off" function by default.
This solution is more commonly used.
