Hi! This behavior has something to do with compound unit type like Watt or Pa. The display value via Inventor API is done in database unit (not document unit). So everything is converted based on mass = Kg, length = cm, time = sec, temperature = kelvin, and angle = radian.
Pa = Kg/(m*sec^2) = 1/100 * Kg/(cm*sec^2)
So the display value via API would look 100 times smaller than the parameter value.
Many thanks!
Software Test Engineer
