Problem with pop up windows
els8STYX
Observer Observer
els8STYX
Observer
Observer
some pop up windows i get at inventor look like this.
And it becomes a problem when i want to fill something out
has anyone a solution for this?
ampster40
What happens when you click the Skip button?  Typically that allows you to name a file what ever you want.
But, it almost sounds like you do not expect that pop up to exist, if so then double check with whom ever sets up Inventor within your organization.
HTH
els8STYX
Observer
Observer
if i skip the save window just opens up with partx.ipt and i get to rename it.
But thats not the problem.
The problem is tha small and crammed pop up window. and i cant resize it to fit all the words
Frederick_Law
Are you using scaling on the display?
Gabriel_Watson
If you are using multiple monitors with very different resolutions this may be the cause.
johnsonshiue
Hi! Please install all critical Windows updates and update the graphics driver. Go to Windows Display settings and select the recommended scale and resolution. Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> uncheck both boxes.
Many thanks!
Software Test Engineer
