Problem with Extruding
Hi
I am currently evaluating IV and ideally want to implemnt it in to our work so Iam totally new to it.
i I am trying to draw 1 leaf of a double door (timber) it has 3 panels in each leaf with the center panel a different shape. part attached to this message
Question 1: I am working on a multibody part to use in an assembly later. I have drawn the sketch for the door and fully constrained it, when I extruded it (mid plane) I select new solid part and it wants to merge the parts together and can seam to keep them all seperate.
Question 2: how would I sketch a profile I would like the frame rails and stiles to have and can I sweep a profile around the frames to cut this profile into rails and stiles?
Thanks for any help
WHolzwarth
Maybe this is a first step (2016 file).
I had to add several coincident constraints in Sketch10 to get it.
Walter
Walter Holzwarth
