Problem with corner relief
nuclair
Message 1 of 8
nuclair
Dear All,
I'm trying to get my corner reliefshape to be a tear, but somehow in the part attached i'ts not changing its form as shown in the picture below. I've tried a lot of things but i'm not finding the solution..
Any ideas??
Thanks in advance!
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
You must choose a laser weld corner type. For this purpose, it will be necessary to change the modeling strategy.
(view in My Videos)
Kacper Suchomski
Message 3 of 8
nuclair
Thank you so much for this very clear solution!
Unfortunately I'm tring to model exactly the same as your video but the following keeps happing.
When i use Corner seam i can see the proposed corner seam in green is looking good:
But then i hit oke and the gap size is bigger then the preview:
I've tried a lot of different tactics but i'ts not working for me.
Any ideas?
Message 4 of 8
nuclair
I've been trying some more but i cannot manage to recreate your video somehow. I've done everything EXACTLY the same but my corner seam is not closing the gap on 1 side.
In my opinion this has to be a sheet metal default setting right?
Message 5 of 8
kacper.suchomski
It's hard to say anything based on the description.
Record your workflow and attach the file.
Kacper Suchomski
Message 6 of 8
nuclair
Dear,
Sorry late reply, have been on holidays.
As you can see below i (think) do exactly the same as your video. Only the result is different.
Please let me know if you find any differences, or have any clues?
Message 7 of 8
kacper.suchomski
Why didn't you change the relief type in the bend dialog?
Kacper Suchomski
Message 8 of 8
nuclair
Dear,
I've got the corner type changed in my sheet metal defaults. So this is tear on standard.
Greetings Ivo
